![]() UTC
Posts: 1941 Location: Hamilton/Kirikiriroa, NZ |
![]() Gina, 1965 Vespa 180SS, Bella,1968 Vespa 150 Super, Mia, 2017 Vespa Primavera 70th Anniversary 150ie, Gabriella, 2017 GTS300 ABS
I was hoping to be able to test the horn for the 180SS before getting it installed. The engine isn't at the point of being started so I was wondering if it's possible to test the horn some other way? The scooter is a non battery model. Excuse my electrical ignorance.
![]() 73 & 74 Rally, 76 ET3, 80 P200, 61 Ser 2, 65 Silver Special,, 2015 HD Road Glide Special
Posts: 5271 Location: Oceanside, CA |
Got any other running scooters with AC power horn or headlight? Tap off that. Idle should produce enough voltage to let you know if your horn will work or not.
![]() 1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
Posts: 1084 Location: York, PA (the intellectual center of the universe) |
![]() UTC
Posts: 4939 Location: Australa, Mate |
![]() 1997 Italjet Formula 125, 2 matching N.Z. '69 VBC Super, 177cc Racer, VespaCross Bodge, Puch SRA150, Piaggio Zip 100! & others
![]() UTC
garncarz wrote: |
bodgemaster
![]() 63 GL, 76 Super (x2), 74 Primavera (x2), 79 P200, 06 Fly 150
Posts: 7236 Location: So Cal |
The horn's easy to install. Finish building the rest of the scoot, and once the engine's running, hook it up and test it.
![]() UTC
pigletpilot wrote: Thanks, but a little awkward in NZ with our 240V system and different plugs. Everything is able to be overcome I guess. You will probably recognise some of the pics from page 1 of "Ode to Speedy" |
![]() UTC
