Vespa GTS300ie Sport & Vespa LXV50
I'm trying to get my LXV50 started. It's been sat for a year, I ran it dry when I left it, pulled the battery and I'm now back and I want it going. Battery reconnected, fresh petrol added and it's just spinning and not catching.
Am I best just cranking it with no throttle or give it some throttle as well ? I've seen a guy online with a papertowel cardboard tube blowing into the fuel tank with the engine cranking - could this help ?
Would some carb cleaner into the airbox help ? I can't believe the carbs would need cleaning as it was completely run dry ??
Any other ideas would be very welcome. Thanks.
@jkj-fz6 avatar
@jkj-fz6 avatar
Sounds like your battery is weak. Have you tried charging it? The carbs may need cleaning; some gunk could remain even after you've drained the tank. I've never heard of the cardboard tube thing but I can't see any way it would help.
Try charging the battery first, and if you can get a multimeter and measure the battery voltage, that may help us diagnose the trouble.
[ Time: 0.0100s ][ Queries: 3 (0.0037s) ][ live ][ 334 ][ ThingOne ]
