Piaggio MP3 500
Piaggio MP3 500
Hi Guys
Hope everyone is well.. as the title says i happen to have experienced this while only leaning right as i go around a round about.. a bit bizarre.. it starts like a wobble then the right hand front wheel somewhat losses momentary grip. The left side not so much. i never had any of this when using my other bikes going around a round about.. mp3 is very stable though on high speed..
However i noticed that when i put a bit of counter steer (as if driving my Suzuki Intruder Trike) it sorts it out. Do i need to worry about anything? Or this is the nature of this scoot? I have checked the bearing play on both front wheels and they are ok. Also the parallelogram and steering action are smooth.
One thing i noticed though is the rear tyres are a bit squared/ flat profiled in the middle. I bought the MP3 secondhand so it came to me like this. Would the rear tyre have any effect on the front two wheels? Thanks in advance for your advise guys!!
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
If your rear tire is worn to the point of having a flat area you need to replace it. Yes. A flattened rear wheel can make a bike feel squirrely in curves.
2016 Mp3 500ie Sport
The Mp3 needs to be counter-steered like any other motorcycle otherwise its going to be unstable.
It might be worth getting the suspension checked and making sure the pre-set is correct on the rear shock-absorbers. If this does in fact only happen on right-turns / leans and not left-turns / leans then I would wonder if the suspension is okay. Bad shock-absorbers can also cause the bike to feel unstable in a corner especially if the roads are roughly paved.
Also check the tires are properly inflated to the right pressure. A worn down center combined with lots of highway (tarmac) riding can wear down the tires much faster. I keep a mini-pump with my bike at all times so I can add or reduce pressure for road conditions or when I'm doing long highway rides to reduce wear.
Piaggio MP3 500
Piaggio MP3 500
The counter steer on a normal motorcycle is an intuitive movement that you do..you almost don't notice you are doing it.. but with my MP3 you really feel a bit of weight doing the counter steer.. like i riding a Delta Trike.. i will check my tire pressures and if not sorted i will look into the suspensions.. i have ordered a new rear tyre as well. Wobble or no wobble i will replace it due to the flat profile in the middle anyways. Thanks guys..
[ Time: 0.0096s ][ Queries: 3 (0.0031s) ][ live ][ 342 ][ ThingOne ]
