@macgerk77 avatar
Wrecked '61 VNB '65 Allstate '74 Rally 200
@macgerk77 avatar
I happened to knock over my bottle of gearbox oil just now, and when I picked it up, I noticed on the back in small print "meets gl-5 specification"
I asked the guy at the autoparts store for gl-4 specifically, and repeatedly.
So I immediately drained my gearbox (yes, at 2:45am), and I'm gonna go hit napa for a bottle of sae 30 non-detergent tomorrow.
Oil's been in the bike for something like 2-3 months of infrequent riding (maybe 15miles a week).
Should I be worried that the oil has caused any damage/wear? Or am I just being neurotic?
@roland87 avatar
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
@roland87 avatar
Don't worry all will be ok.
GL150
GL150
IIRC GL5 damages yellow metals like brass. I'm new to scooters so I don't know if there's any brass in there. It's unlikely to do immediate catastrophic damage so I'd just change it to the right stuff and not worry about it.
@hec_in_omaha avatar
1980 P125X US Spec
1980 P125X US Spec
2:45AM! Geez I thought I was bad!
The difference between GL4 and GL5 is the addition of phosphorus and sulfur to GL5. This can react with copper and brass with disastrous results. Based on my P125X gear box, the only components I can think of that may be brass or copper is the clutch bushing and clutch actuating plunger. I was always told to not use GL5 oil in gearboxes that have yellow metal components. I suppose you could pop the clutch cover off and remove the clutch to take a peek at the parts I mentioned for peace of mind.
Hec
@macgerk77 avatar
@macgerk77 avatar
Believe me, crawling around under a scooter in my pajamas getting grease smudges on my face wasn't on my before bed "to do" list
Don't wanna pop the clutch cover without a replacement rubber ring on hand… I'm certain the one in there is "curator of antiquities" levels of old.
I guess I'll add one to the parts order I need to place.
@oopsclunkthud avatar
3:5
The only yellow metal is the bushings in the clutch. The bigger issue with GL5 is it's too slippery in shear for a wet clutch.
No permanent or even short term damage, just change it out and all will be fine.
@roland87 avatar
@roland87 avatar
And thrust washer.
1980 P125X US Spec
1980 P125X US Spec
roland87 wrote:
Good call! I forget about the thrust washer being yellow metal.
Hec
@gickspeed avatar
@gickspeed avatar
Seals are probably melting right now and i am getting my popcorn ready for a 9 pager with at least 4 pages of jetting "advice."
@orwell84 avatar
@orwell84 avatar
Just 4 pages? I think you're being optimistic.
3:5
GickSpeed wrote:
Seals are probably melting right now...
🦭 Save The Seals 🦭
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
are seals actually affected by GL5 or is that just a joke? I've heard about the brass bits before, but never anything about seals.
3:5
just a joke.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
i figured, but I wanted to be sure!
@108 avatar
V range 50s
@108 avatar
V range 50s
Jetting advice is my favourite type of advice.
@aiosi avatar
@aiosi avatar
You definitely do not want to get it anywhere near the muffler bearing!
@macgerk77 avatar
@macgerk77 avatar
Thanks for all the input guys
Nice one lol… this bike is actually my membership card to your "screw 9 pages of jetting advice" club…
[ Time: 0.0127s ][ Queries: 3 (0.0018s) ][ live ][ 334 ][ ThingOne ]
