Mp3 250
Mp3 250
Hello everyone, I would like to change the oil on my mp3 250 and am a bit confused. I understand being in the Midwest I should use. 5- 40 full synthetic do I need to go scooter oil specifically or will motorcycle oil do the same job? If a scooter oil is needed can it be purchased at an O'Reilly's or AutoZone or do I have to order it online. Also, any specifics on hub oil? Thanks in advance.
@tszarathusra avatar
Vespa C38 - S50 4T Super.
Use what the manual says is the best answer/approach.
The manual will specify certain standards that the oil should meet. It will also specify weight for the temperature in your region.
You will need to get information about the temperature in your region somewhere else.
Mp3 250
Mp3 250
Agip city grip hitec 4T is what the manual states if I remember correctly, is that a certain brand or should I just look for something that says 4T?
@25bikez avatar
2009 Genuine Stella 2T (Sold). Helix Hunting.
@25bikez avatar
Your owner's manual will give you options for weight, depending on your ambient temperature. It'll say something like 5W40 4T API SL.
5w40 is the weight
API/SL is the grade/additive package (it changes every couple of years as refining standards change). API is an American grading system, JASO is the Japanese grading system, etc.
4T means 4 stroke engine oil.
The information will be printed on the bottle.
I have been using Shell Rotella T-6 5w-40 for the last 15 years with no issues, It meets all the manufacture specs for the scooter
MP3 250cc 2009
MP3 250cc 2009
ditto,
same here
@wbdvt avatar
@wbdvt avatar
I have been using for the last 6+ years Castrol full synthetic 5-40 4T in my scooters including 2 that have the same engine as yours. I buy it by the 6 pack on Amazon
I also use a HiFlo 197 oil filter as it has a 14 or 17 mm hex nut on end to make install/removal easy
@bean_counter avatar
2016 BV350 White
2016 BV350 White
You can buy hub oil at your local auto parts store.
[ Time: 0.0095s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
