@norman avatar
1978 MotoVespa 160GT, 2009 LML Star 2T (Stella), 1961 Lambretta S2
@norman avatar
I was not impressed with the SIP premium quality blue gasket set. It was too thick and the alignment was off for some of the bolt holes. I junked it and went with a cheap generic tan colored paper set that has worked fine.
It was similar to this one from Scooter West:
@orwell84 avatar
@orwell84 avatar
I think I used a generic gasket set too. No leaks. I ordered a bunch of extra carb and reed block gaskets.
None of those generic ones are lavender oil infused though…
1963 VBB
1963 VBB
@chandlerman avatar
Innovator
89 Days Since Last Explosion
Innovator
@chandlerman avatar
scootermercato wrote:
None of those gasket sets listed are correct for an LML 2T
There's also that... Razz emoticon
This is the correct gasket set for a Stella/LML with a reed intake: https://www.scootermercato.com/Scooter-Parts/Gasket-Sets/472133
@safis avatar
@safis avatar
I use SIP's premium gaskets (if customer pays) and Piaggio's (thin paper type for older engines, green thicker ones for PX engines). SIP's have the same thickness as Piaggio's green ones but higher quality paper. BGM's gaskets (the ones with the infused glue) are CRAP!!!
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
OP lives in Belgium so I'm sure he's going to buy over there.
@108 avatar
V range 50s
@108 avatar
V range 50s
If in Europe, try these guys.
https://www.gaeskits.shop/#!/products/lf-sets-px80-200
Not sure if they have a specific lml one though
parallelogramerist
parallelogramerist
x2 on the crappy BGM gaskets!!!
@roland87 avatar
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
@roland87 avatar
I use original paper gaskets and SIP blue. Never have any problems.
@norman avatar
@norman avatar
Thanks for the responses guys. It sounds like the BGM sets are to be avoided. Come to think of it, I've a feeling that's what I used on my last rebuild of that engine, so it could well be the reason for the oil leak.
Regarding an LML-specific set, I'm not too bothered about that - I can always get the reed valve gaskets separately anyway.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
you need an lml specific case gasket as well.....
@colinbelgium avatar
VBA1T/Px200 iris/VNB6T
I use original gasket kits + a very thin layer of Dirko HT silicone gasket maker on both sides. Never had issue.
@subetherbass avatar
so, you want to rebuild with the best gaskets available...
Ask Linda, hers are by far the best!
Go on... You (that know me) KNEW it was coming, but poor Norman walked smack-bang into that one!
I can smell the Lavender that will need to be applied from here
@norman avatar
@norman avatar
Ah, I didn't know that. It will certainly limit the choice to just the economy type then I guess ...
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
This.
And the reed block and airbox gaskets, but that's easy enough to cut your own since they're small.
@norman avatar
@norman avatar
Point taken
Strange that so many places sell the same gasket set as being suitable for both P-range and LML. I'm looking forward to cracking the cases on mine, I bet it was a P-range gasket I used when I last opened it up a few years ago.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
If you have the reeded motor, I don't think you could have used a P-range gasket, unless you fabricated part of it yourself, and maybe not even then. (I'll have to ponder a little on the feasibility of that one)
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
This
[ Time: 0.0096s ][ Queries: 4 (0.0032s) ][ live ][ 334 ][ ThingOne ]
