@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
What are your thoughts? Ok to use as is with new rings or overbore or replace? TIA.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
does it catch a fingernail? you can always run a ball hone over it if it does.
what cylinder is that? I had to ask.
@az_slynch avatar
@az_slynch avatar
Honda moped? It looks like what was on my Express SR.
Or maybe an Suzuki FA50?
If Honda, order a "B" piston and hone it.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
the ball hones are great but once you get too much clearance it's over. that's what happened on my Malossi 166 kit - I cleaned it up great but then it was piston slapping so hard that it needed to go first over. not too much work to try and clean it up though.
@markosmarkos avatar
Honda NC50. In signature. Honda Express, same cylinder as Express SR.
@az_slynch avatar
@az_slynch avatar
Here's a bad influence:
https://www.treatland.tv/SearchResults.asp?Search=Nc50
Treats is a great stateside source for moped/moped parts.
@garncarz avatar
@garncarz avatar
So, if I hone out the scratches and can keep the ring end gap in spec, I'm ok with the standard piston size? And yes, its an NC50.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
it will be ring gap and piston to bore that say you made it or you failed
@garncarz avatar
@garncarz avatar
So many modes of failure, so few IQ points. Thanks. More to follow.
@orwell84 avatar
@orwell84 avatar
Give it a quick bone with the ball hone, bud.
@colinbelgium avatar
VBA1T/Px200 iris/VNB6t
Same here, and replace rings.
Insert new ring into the cylinder, push it down a few inches using the piston upside down, to makes sure the ring is straight, then measure the open gap of the ring with a filler gauge et check if within factory specs
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Also should measure piston to cylinder wall clearance, to much and piston will rattle in cylinder.
@garncarz avatar
@garncarz avatar
Thanks guys for all of the insights. Hoping to get to it this weekend.
@garncarz avatar
@garncarz avatar
I ran a 240 grit ball hone through and while I can still see the scratches I can't feel them. No glaze anymore and a nice 45 degree crosshatching now. Installed new rings, clips and gaskets. The piston diameter, cylinder bore and ring gap are all within specs. Going to run a compression test later today. Fingers crossed.
@orwell84 avatar
@orwell84 avatar
Hone looks great. Text book cross hatch. That should do it.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
There's a real good chance that will work. Nice hone job!
[ Time: 0.0138s ][ Queries: 4 (0.0054s) ][ live ][ 331 ][ ThingOne ]
