Hello everyone,
So the battery voltage on my piaggio mp3 250 is 12.4 without any load. Then i start the engine and it falls immediately to 12.1 then continues to steadily drop. Revving the engine has no effect it just keeps dropping.
So i unplug the connector between stator and regulator and measure the unloaded voltage of all 3 phases while revving the engine. They all measure 0.12v @ idle and ramp up to 0.95v @ full throttle.
So i pull the stator (it shows no sign of damage or overheating) and measure resistance across all 3 polarities = .4 ohms.
So i check for shorts between output leads and the laminate core. There aren't any.
i can't measure the flux of the magnets in the rotor, but i did an informal test with a steel knife. They all grip the blade well and evenly.
Anyone ever seen anything like this?
⚠️ Last edited by mikewax on UTC; edited 3 times
