@web-tech avatar
@web-tech avatar
My tilt lock motor failed on the mp3, since the motor failed, I could not get the tilt lock to unlock. So I was stuck, luckily I was at home.
Once I figured out how to replace it, it was fairly easy. Hardest part to figure out was how to get the potentiometer/rotation sensor lined back up, because it was locked when I took it off, so it released when I removed the motor.
Parts mp3 save me again.
Mp3's back on the road.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
no need to replace open it and grease it and set the sprockets right there are alignment point on the sprockets
if the electric motor burned out just replace that its w wipermotor
@web-tech avatar
@web-tech avatar
It was the wiper motor I replaced. I had a spare tilt lock assembly from another scooter and used that motor.
But because it was locked with the old motor on. It released when I took the motor off. So I had to make sure the shaft that drove the rotation sensor was still in the right position. Because it moved when I took the old motor out.
All I had to do though was cycle the motor manually with 12 volts to get it in the right position, and then the sensor lined up.
I should have never taken the sensor out. I forgot why I got to that point. But the sensor was out when I took the old motor out.
[ Time: 0.0099s ][ Queries: 3 (0.0036s) ][ live ][ 343 ][ ThingOne ]
