I cleaned up px 210 malossi Barrel with. Patio acid fine gaining paste 1200 wet n dry bought piston by correct letter from malossi center Italy bolt on Barrel but I had bad noise which never had before I thought it was the head ect so after taking off God how many times I cleaned edge of head by a mm everything still a noice so I nearly gave up I thought piston ring was tight I thought that's the way it is. But the piston ring was upside I contacted the malossi and complained they sent me this link I cleaned out ring slot with wet n dry wiped a little I must flip the piston ring the right way problem solved I didn't bother matching casings or changing crank timing as top port is already matched side ports are increased by the piston design work a treat 125 main jet .I had to google problem malossi and it bought me to forem so I post this topic so don't catch everyone that hasn't seen a semi transcopal piston ring it's on page 31 of download on this link. https://wemalossistore.blob.core.windows.net/files/montaggio/pdm/7317163.pdf
@greasy125 avatar
@greasy125 avatar
cool story bro. how many times are you going to post the exact same thing?
also, maybe try a little punctuation? a line break perhaps? or a paragraph?
@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
I'm not sure punctuation would help. It's like someone asked ChatGPT to write a question about a vespa engine while tripping on PCP.
[ Time: 0.0124s ][ Queries: 4 (0.0053s) ][ live ][ 334 ][ ThingOne ]
