Anyone have the paint code for a 2022 sei giorni? Looking online I am getting all sorts of answers.
Dave
Thanks Dave |
Moved this out of the wiki discussion area (where it will never, ever be seen) and into General Discussion.
If by chance someone does have the paint code, then adding it to the wiki would be awesome. |
Grey HX
Only "Grey HX", no numbers, etc. You can scan the QR code on the inside of your vehicle (under the seat, helmet compartment out), there you will also find the above designation. Please update the Wiki and post a Link. |
Updated the wiki. I don't have the accessory codes or the PPG equivalents, though.
Modern Vespa Paint Codes |
![]() GTV / GTS, 1961 Lambretta LI Series 3
Posts: 537 Location: Somewhere on the Island of Great Britain, East Coast, Last time I looked. |
Paint code is on the plate inside the chassis usually 3 numbers and states paint code also explains were to find it in the owners manual.😉👍
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 45010 Location: Pleasant Hill, CA |
BUGGSY wrote: Paint code is on the plate inside the chassis usually 3 numbers and states paint code also explains were to find it in the owners manual.😉👍 |
![]() 1979 P150X, 1983 P200E, 1987 PK125XL Elestart, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 4753 Location: Veria, Greece |
SaFiS wrote: 770/B, auxiliary code is HX… |
Just to make things extra complicated:
https://www.amazon.com.be/-/en/Piaggio-Metallic-Dolomiti-Varnish-Hardener/dp/B07SSHLQVB?language=en_GB |
I'm actually seeing a lot of different paint codes given for touch-up paint for the Sei Giorni, so I understand where the OP was coming from.
This site says 742/B. This site says 798/B. And I see a bunch of threads here on MV that say it's just "Grigio HX". Which seems... not right, compared to every other paint code on every other Vespa. In fact, I'm nearly certain that "Grigio HX" (or "Grey HX") is almost certainly the name of the color, not the paint code. |
This is from Glasurit's paint system. And I'm pretty's sure that Piaggio probably has some directive info in their system on how to exactly paint the body like they did for the 946 Armani (primer, pressure, angle, temp, etc.)…
Positive
SaFiS wrote: This is from Glasurit's paint system. And I'm pretty's sure that Piaggio probably has some directive info in their system on how to exactly paint the body like they did for the 946 Armani (primer, pressure, angle, temp, etc.)… |
GermanGTSDriver wrote: Hmmm… The grey matt Sei Giorni was available since 2019 (not 2014)… |
second time I've done that, need to look where people are from😉👍
jimc wrote: Only in Europe. The US VIN plate is outside above or below the glovebox, and doesn't have the paint code on it. |
