I'm debugging a fuel delivery problem on my 2006 LX150 with a Keihin CVK KT. I'm struggling with it since neither my Haynes manual nor the Workshop manual describe this exact model. I'd hoped that a thorough cleaning would resolve it, but no luck, so now I need to understand it a bit more to further my debug:
1. Is there anything to adjust on it? Haynes and Workshop refer to the flow screw or pilot screw, that needs to be backed out by two turns. Mine doesn't have that. I have a screw that looks similar (1st picture), but its purpose is to drain the float bowl (2nd picture).
2. What causes the diaphragm (3rd picture) to move up against the spring (thus causing the needle to unblock a fuel passage (4th picture)? It doesn't seem there is any vacuum source behind the diaphragm that would pull it up.
3. What is the port for that has this hose sticking out of it (5th picture)? This hose is connected to some canisters. I suppose that this is sucking unburnt fuel vapor into the carb for emissions purposes, probably has nothing to do with the operation of the carb.
FWIW, my VIN is ZAPM448FX65004931, engine # is M443M5115
Thanks!
Toby
