Mp3 500
Mp3 500
The check engine light is on. I think it is from the exhaust gasket leak that ran for a while before I fixed it. How do I turn it off? thanks Jim
@wbdvt avatar
@wbdvt avatar
Is on consistently? I don't think exhaust gasket leak will cause the CEL to come on
Damaged or disconnected lambda sensor?
Mp3 500
Mp3 500
Yes, it is on all the time-thanks Jim
@wbdvt avatar
@wbdvt avatar
The exhaust header should have a collar on the header pipe that was an attempt to direct leaking exhaust gases away from rear brake line. In past a leaking exhaust gasket could melt the brake line
The lamda sensor should be above this collar. However perhaps the wiring to it got damaged from hot gases. Would be area to check
Mp3 500
Mp3 500
Thanks-will do and report back-Jim
Mp3 500
Mp3 500
The wiring did not get damaged. The sensor is being replaced.--thanks Jim
[ Time: 0.0095s ][ Queries: 3 (0.0022s) ][ live ][ 335 ][ ThingOne ]
