ScooterLover73 wrote:
I'll do a conversion from NM to ftlbs later to find the lower limit. Thanks.
I wouldn't normally be concerned, but I'm not sure what's on the page is referring to those 5 bolts.
Also, someone told me it was 16 ftlbs, so that also confused me.
"wheel fastening screws" [33-37nm]
so, translation: wheel attaching bolts 24.3396~27.2898 ft/lb
1- never believe anybody about torque values, verify
2- never commit torque values to memory, that way you can't conflate them
(there are a very few exceptions to this rule)
interestingly enough, the GT/GTS which uses a similar arrangement and same size fastener lists the torque spec at 15~18 ft/lb. but yeah. follow the manual.
