After meticulously cleaning out a very gunked up 4T Bajaj chetak gas tank, I put in a brand new tap. The bike came with a ton of spare parts and the spare tap was still in the plastic.
I screwed the tap in tightly (10mm head = 6mm screw so I didn't want to go nuts), but when I turned the tank on to test it, I get a drip.
The gas line to tap is lower than where the drip is coming from. The tap gasket (tap to tank) seems to be great as well.
It looks to me like it's where the fuel rod meets the tap. There are two surface plate screws - both are very tight/flush.
I haven't taken the tap apart to diagnose, but has anyone run into this issue before or may offer a solution?
