My 2023 Primavera 150 is due for its first service. In the manual, it shows that the valves are to be adjusted at that interval (1000 km, 621 miles). The guy in service I spoke to said that 9 times out of 10 the clearances are fine. And that they recommend doing at the third service instead.
It's a difference between about $120 and $350-$400 without and with doing the valve clearance adjustment.
A friend and I will be trailering it to the shop that is over an hour away, so the engine should be pretty cold. So no issues there.
What do all of you guys think? Should I do it "by the book" or just wait till the third service to have the valves adjusted?
