Are they related?
Background: Purchased a 2009 GTS 250 with 7.4k miles. Maintenance basically unknown but seemed like a sound scooter. From what I was told, purchased in FL, ridden there, brought to VT, then sold, ridden a little here.
Tires were date code 2015 so during some maintenance replaced. Battery has a date code of 8/16, is an AGM type so I deduce some maintenance done in 2016.
Issue is that when doing oil change, there are some small metal, probably aluminum, flakes in strainer. See pic.
Coolant was very low but no obvious sign of leaks. All clamps still factory. When draining coolant it looked very diluted. Got like 2.5 cups out when draining. See pic. Filled with new coolant but no leaks. Disclaimer: haven't started scooter as waiting on tire mounting, new bearing for variator cover, so it may leak when under pressure.
Thoughts on metal flakes? Seems to me minor.
