@johanrsa avatar
1981 P200e ,1988 PX200e and '04 ET4 125
@johanrsa avatar
Good day and thank you for the opportunity to be part of this great forum. I have been silently pirate reading here from South Africa. I recently purchased a second VSX1T, I am a bit large for the small frames.
The scooter has been standing for many years, but is in excellent condition and I got it going (kickstart) within 3 days of tinkering.
The electrics requires some faultfinding.
Faults are:
No reaction to electric start: Resolved-- I grounded the pink clutch safety switch wire.
Indicators not working (also indication lights on speedo) Resolved----2 loose wires, soldered.
Fuel level not workingResolved--Loose connection white/blue wire to speedometer terminals
What works:
Horn
High/Low main beam --intermittent.
Rear light
High/Low main beam indication on speedo.
Some guidance on the faultfinding process would be much appreciated.
I do have a multimeter and basic knowledge, and have a few versions of P-Series electrical wiring diagrams. I have not made time to spend more than an hour looking at the basics, battery, fuse, some connections etc.
I do have one specific question. What is this single pink wire in the middle and where does it go? Resolved--This should go to the clutch safety switch or bypassed to ground if desired.
Thank you in advance.
⚠️ Last edited by JohanRSA on UTC; edited 2 times
@ray8 avatar
@ray8 avatar
To the speedo.
Have you replaced and fully charged the battery?
@johanrsa avatar
@johanrsa avatar
Thanks Roy
Yes, the battery is new and charged.
I could not find any sensible place on the speedo for the pink wire to go.
After further searching I am leaning towards the clutch safety switch (that I suspect has been removed).
I will update on progress. Feedback: Switch was removed by previous owner. I connected the pink wire to ground and it starts just fine now.
@108 avatar
V range 50s
@108 avatar
V range 50s
JohanRSA wrote:
Thanks Roy
Yes, the battery os new and charged.
Yeah, I'd guess clutch switch too.
I'm guessing they're usually removed and not replaced when a clutch cable is replaced.
I don't think it needs it for an electrical start.
But I'd ghetto test the starter motor with a 12v battery.
Also for the indicators too. Use a 12v battery to make sure the pin connector on the cowl and front lights are working. Then trace the fault backwards.
Usual suspects are a bad earth, or faulty indicator relay
What year PX is it?
Jet Eye Master
PX221 MHR, PX200 O tuned, PX181 M1XL, PX125 O tuned and some motorbikes
Jet Eye Master
+1 clutch switch.
The connector might be tucked inside the gear tube. The switches are difficult to remove, so is a chance it's still there.
If you ground that wire the starter button might work.
@johanrsa avatar
@johanrsa avatar
Thanks Gents!
The Chassis Vin nr shows up as 1988, the engine number as 1985. I've wondered if it was possibly built like that or whether the motor was replaced at some time?
@safis avatar
@safis avatar
Battery is there only for starter and horn. Indicators and fuel level work on the AC side when engine's running. Lights should also run on AC unless someone rewired them or work of battery for a specific market. That disconnected wire is for the clutch safety switch. You can ground it and do a test if the starter will work…
@johanrsa avatar
@johanrsa avatar
Thanks to your good advice, I have made good progress.
The pink wire was indeed for the MIA clutch switch. I Earthed it and 'vroom' ... she starts via starter switch in fraction of a second.
Found loose soldered wires in the indicator switch unit and soldered them (white/blue and brown)
Took her for a test drive.
Indicators left and right rear comes on but are flashing fast/irregularly. Intetestinhly this scooter does mot have frong indicators, nor a cybbyhole/glovebox
The main and low beam headlight go weak at high revs. and at low revs they are bright again. Being powered by AC from the stator this has me stumped.
Any suggestions on the 2 issues please?
@108 avatar
V range 50s
@108 avatar
V range 50s
Dim headlight at idle and weird flashing indicators and flashing speed is normal for the PX and AC power.
The indicators don't flash at the same time right? It's more like a Christmas tree…
Always thought it was weird… but seems like it's by design
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
It is by design, to reduce headlight flicker.
@johanrsa avatar
@johanrsa avatar
I have to clarify the dim headlights: The problem is that they go dim/very weak when the speed/revs are high.
⚠️ Last edited by JohanRSA on UTC; edited 1 time
@108 avatar
V range 50s
@108 avatar
V range 50s
Ah got you.
I'd look at the reg/rec, usually that's faulty. Had same symptoms on a Honda bike.
The other thing afterwards to look at would be the stator.
@johanrsa avatar
@johanrsa avatar
Unfortunately I have not yet resolved my PX Arco issues.
The battery is not receiving any charge and AC is weak at high RPM.
The stator is the 5 wire Green Blue(correction) Red Black White version.
CDI: White Red Green in and Green out
RegRec is 5 pin A A G +B Earth.
I have compared this to a number of electrical diagrams and have not found one matching this setup.
Is the regulator perhaps a mismatch for the stator? Do I need the M C B+ G G version?
Please advise.
⚠️ Last edited by JohanRSA on UTC; edited 3 times
@johanrsa avatar
@johanrsa avatar
The CDI
@safis avatar
@safis avatar
Wrong regulator for your loom. You need this one...
@johanrsa avatar
@johanrsa avatar
Thanks for the quick response SaFis, I am on the track of the correct Regulator.
@johanrsa avatar
@johanrsa avatar
Just to let you know that I received the correct regulator (GG+B C and earth) and all looks good now. The headlight is brighter and constant, no longer fading with increasing revs as with the wrong regulator.
Thanks Safis and others for your assistance.
[ Time: 0.0175s ][ Queries: 4 (0.0061s) ][ live ][ 323 ][ ThingOne ]
