I am stuck in a no start, plug gets wet and used to spark when I pulled it out then I cleaned it with some break clean and cleaned up the isolator a tad and then it stopped jumping the gap.
It will jump to the engine but not across the plug so I assume the plug is broken.
I am struggling to figure out what plug is supposed to be in there though. Looking online I have seen a few different NGK plugs that are claimed to be the correct one:
BPR7ES (what is in there now)
BR7ES
BP7HS
B6HS
So does anyone actually know what to use?
I belive the engine is pretty much stock configuration. Idle jet is a tiny bit richer than stock is all.
I discussed in another thread that my plug has a bit of a two face look. Most of it look golden and perfect but then a bit of it looks damaged and overheated. As I did not put this plug in, I don't know if that overheating stuff is the current tune or not. I've only had my PK for a month and a bit.
