Hi all hope all is well ?
Now for the question, does anyone have a px 80 E flywheel Ducati 996156 spare or an alternative for sale?
Tried everything and I'm convinced the flywheel is too weak.
TIA Garry
Now for the question, does anyone have a px 80 E flywheel Ducati 996156 spare or an alternative for sale? Tried everything and I'm convinced the flywheel is too weak. TIA Garry |
![]() Weird 80's Vespas & Cool Vintage Lambrettas
Posts: 15090 Location: The state of insanity, SoCal |
PX80 used the same electronic flywheel as the 125/150 & 200 so they're widely available.
I'd recommend a lighter one for the 80 over something like a stock 200 E start piece.
Positive
Hi thanks for the reply, but I've ordered 2 and they dont seem to fit, are the cases different on a 80e?
Regards Garry |
should fit no problem.
let's see some pictures of what you're working with. namely the stator and the case. also, do you have an aftermarket kit on there or is the barrel stock? |
Hi
In the first picture you have 93mm across Second picture 27mm 3rd 184mm 4th 20mm I'm running a dr 130 kit Bgm stator TIA GARRY ![]() ![]() ![]() ![]() ![]() ![]() |
what is not fitting? walk us through that as the PX80 was never sold in the USA. Just viewing SIP, the same crank and flywheel from PX200 fits the PX80.
I e bought 2 online and when I try to put it on its rubbing on something to the point the flywheel wont spin
Ik m going to take the old flywheel to Ron daily's and see what he has to match The whole thing is a complete x file Regards Garry |
Posts: 724 Location: UK |
Is it catching on the bolts holding the stator on? Can you put marker pen on the back of the flywheel and then gently spin it until it starts to rub. then see where the marker pen has rubbed off.
Jet Eye Master
PX221 MHR, PX200 O tuned, PX181 M1XL, PX125 O tuned and some motorbikes
Posts: 4942 Location: London UK |
SIP agree with everyone else. PX80 uses a PX125 etc. flywheel.
https://www.sip-scootershop.com/en/product/flywheel-piaggio_50024000 |
![]() 1979 P150X, 1983 P200E, 1987 PK125XL Elestart, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 4719 Location: Veria, Greece |
Can't make really well from your pics but you need to cut the extra lip for newer flywheels. Also, the dust seal lip looks like it's bent and not round...
And FYI, BGM stators are crap... ![]() Cut this lip if it's there...
![]() Bent dust seal lip...
Dude I've literally just read the same here
some early p-range casings wont let a disc flywheel sit fully "home" on the crank, they have a web of ally at the front of the casing , that the flywheel doesnt clear. either machine the cases. Now you have sent a photo the mystery is resolved. One thing do you need to machine right back? Thanks for the help everyone |
I've had closer look. Yes slightly bent and a bit of the web left the rest looks snapped off
