Hey guys, I have a few questions about a high performance GTS300ie that I built a little while ago.
I run a Vespa Shop down in South Africa, and decided the best advert for people to see what we do, is to build an all out, wild GTS.
I have since built probably my most expensive personal project, (apart from the two BFA's which are for a different discussion) and its just never pulled like it should. Now, I should add, we are no strangers to building fast GTS's, and have built several bikes that reach well over 160kph.
This one though, ever since the build began, just hasnt gone together nicely.
Its sporting a mix of parts I believe should work well, including the Polini power explosion 300 cylinder kit, a Malossi V4 head, a BGM Variator kit, a BGM torque driver rear pulley, a Polini adjustable clutch and bell, and a free flowing S/S exhaust (have tried several different pipes at this stage, all of them feel the same) and a forcemaster 2.
New parts on the engine include a new Stator, new injector, new polini airfilter with famous airbox mod, new lambda sensor, new cooling system incl pump, new oil pump, new timing chain, new piaggio camshaft, new rockers and shafts, and the usual hardware stuff.
In my experience, this bike should be an absolute monster. However, anything over 80kph, and the rpm slowly decreases and it feels like its just tightening up more and more.
Could this be cam timing? Is there a chance I was supplied the wrong Camshaft? Im fairly certain it was a 300 cam when it went in but i cant be certain. Could the new stator be supplying the incorrect ignition timing? The PADS system tells me the timing is correct according to what its aiming for but could a faulty stator be indexing this timing figure incorrectly? It certainly feels like the timing is wrong.
Im at a point where I dont know where else to look so Im hoping someone here has dealt with a similar issue and sorted it out.
