I currently own a secondhand Vespa S125. Odometer has stopped working at 79,999.9 km and refuses to go onto the next km, despite having ridden a few hundred km since then. Previously there was the same issue - it stopped at 69,999.9 km but began to work again I think after a week or so.
Other details that may be useful for diagnosis:
* Speedometer is working. However, when odometer stops working at 79,999.9 km and 69,999.9 km, I notice that the speedometer needle trembles/shivers/shakes slightly when I am on the move. Normally it moves in a smooth and constant fashion.
* All other warning lights on dashboard except for low fuel and signals do not work. Signal dashboard light is temperamental - sometimes it works, sometimes it doesn't. Right now the signal dashboard light has for some reason stopped working again after I needed to have the ignition switchboard replaced (to fix a problem with the headlight).
Apart from a complete change of the dashboard, are there other steps that I can first try in hope of making the odometer move again? Workshop recommends changing the dashboard but I'd like to explore other options first prior to that.
I don't have much experience nor tools with taking apart the bike, but any information will be much appreciated. Thank you![/img]
