Having trouble starting my mp3 500 cold. After crank it for a long time and give it just a little bit of throttle. Then it will finally start.
Just did a very extensive throttle body cleaning. It does idle better but still has the cold start problem
Wondering what tells the ECU to have the injector fire every stroke in cold mode.
Could it be a bad temperature sensor? If so which one's for the ECU?
