gt 200
gt 200
can someone tell exactly what i need to purchase to get my bike running again?
ive been reading about replacing the ignition switch?
2006 vespa gt 200
@greasy125 avatar
@greasy125 avatar
you'll need a CDI and key set
cheapest and easiest is an aftermarket CDI, then you eliminate the immobilizer function and can use a cheaper key set.
https://scooterpartsco.com/gt-200-performance-c-3637_3641_3771/malossi-cdi-for-vespa-gt-200-other-piaggio-lc-leader-p-820.html
https://scooterpartsco.com/main-category-c-801_4181_4187/keys-and-tumblers-for-vespa-piaggio-aprilia-cheap-p-37141.html
or these https://scooterpartsco.com/300-piaggio-c-801_836/lock-and-key-set-for-vespa-piaggio-p-235.html
or if you want to go the route of keeping the stock CDI with an immobilizer function you'll need this set up:
https://scooterpartsco.com/210-vespa-c-801_802/cdi-for-vespa-gt-200-58054r-p-1171.html
https://scooterpartsco.com/210-vespa-c-801_802/lock-set-for-vespa-gt-gts-gtv-577454-p-234.html
and then you'll code the keys to the cdi.
another option is to pull your CDI and send it to AF1 to be reset and coded to a set of keys, but with the cost of that and shipping I think you're about even stevens on buying new parts.
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
What is AF1?
PeterCC wrote:
What is AF1?
https://www.af1racing.com/
One of our good US parts suppliers, they also offer a reasonably priced reset service for most CDIs and ECUs, to put them back to either factory settings or re-programmed to new keys etc.
@petercc avatar
@petercc avatar
OK, clear, thanks for the explanation.
[ Time: 0.0074s ][ Queries: 3 (0.0017s) ][ live ][ 339 ][ ThingOne ]
