I searched the whole NSM forum and could not find an answer. What would a good idle speed be? I have a portable industrial contact tachometer that I could place on the crank at the flywheel nut.
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
Posts: 1451 Location: Ukraine. Kyiv. |
Jet Eye Master
PX221 MHR, PX200 O tuned, PX181 M1XL, PX125 O tuned and some motorbikes
Posts: 4801 Location: London UK |
Rich enough to do 800? Not really sure what that means. Does it really lean out at low idle? I'm guessing back the idle mixture screw out or do I need to change a jet? If so, starter jet or idle jet?
Lucky
Posts: 10809 Location: Nashville 255 Days Since Last Explosion |
Lucky
Asking what's the "correct" speed for idle is like asking what's the correct thermostat setting for "room temperature."
As Jack said, he likes 800-900. I usually go for about 1,100, but will go 1,300 if I don't want my lights to flicker at idle without a battery. |
Depends on engine and ignition setup.
Forgot to elaborate, 800 is possible on a stock PX electronic ignition system or something weighted. Talking over 2kg flywheel. 1.6kg flywheel and you're looking at 1100-1200rpm, anything lighter and your looking at higher. You want it as low as possible for the health of the gears.
Positive
The "Health of the Gears" I like that statement. I have been running as low as possible but not sure of the exact speed. I will bring home the tach as really check it out.
Posts: 2232 Location: Philadelphia |
I rock it at 1200-1300.
Lower it struggles and the sip speedo turns on and off if it's lower than that. |
Well everything takes a battering when you go into a gear. The cruciform, 1st gear, primary, primary springsā¦
So would you like to "jump in line" at 800rpm or 1300 rpm? Lol |
Jet Eye Master
chippieboy wrote: Rich enough to do 800? Not really sure what that means. |
Posts: 4905 Location: Australa, Mate |
