2009 GTS 250, 7643 miles, $3600
This scooter has just had the following done:
New front and rear Michelin City Grip 2 tires
Oil and filter changed
Hub oil changed
Coolant changed
Brake fluid changed
Variator cover bearing changed
New belt, rollers and sliders
New variator air filter
New Malossi Red Sponge air filter
New fuel injector
New spark plug Denso Iridium
New Motobatt MBTX12U AGM Battery
Center stand disassembled, cleaned, greased
USB Port installed
Has the brown master key
There are some scratches on the right side where previous owner dropped it in driveway.
