@shepys avatar
Vespa T5 classic 1994 and 1980 Vespa p200e
@shepys avatar
When yous guy have used a smoke tested to see if you got a leak in your main seal did you see a lot of smoke or a bit of smoke. Here's a video that of a test I did. I didn't see smoke but I'm not sure what to look for. Lots or a bit ?
@shepys avatar
@shepys avatar
My tester
@qascooter avatar
@qascooter avatar
Hey Shep - something I noticed - be careful with that woodruff key! It's upside down and just waiting to fall right into your engine case!!!!!
Ask me how I know.....
@qascooter avatar
@qascooter avatar
And even without a smoke tester, I've found leaks pretty quickly with just listening, or a bit of soap and water in a spray bottle.
All my leaks, even the tiny ones, have been pretty apparent with this method, unless your test apparatus is leaking - dooohhhh! Razz emoticon
@shepys avatar
@shepys avatar
Yes I did notice it as I was doing the video. I turned the crank around after so it's on the top now.
@shepys avatar
@shepys avatar
have you sprayed soapy water on the main bearing to see if there's leaks.
@qascooter avatar
@qascooter avatar
Yep, and then just dried with a rag and spritzed some oil on the whole area....
@shepys avatar
@shepys avatar
Someone on another forum just told me the fibre gaskets smoke abit at first so it might be just that. I didn't go for a ride to clear it. 😆
[ Time: 0.0133s ][ Queries: 4 (0.0046s) ][ live ][ 328 ][ ThingOne ]
