ScooterWest quotes a 2,000 to 3,000 mile belt life for the specially sized belt that comes with the GTS 300 Polini Evolution Variator (this is NOT the 9-roller variator kit, which can take a standard-sized belt, the evolution Variator only works with the special belt). Does anyone have any experience with the special belt? If so, how many miles have you put on it?
![]() '07 GTS250, '07 LX150, '81 P200E, '78 P200E, '74 VBC1, '64 V90 and 3 Ciaos
Posts: 1582 Location: Tucson, AZ |
That seems like a really short belt life.
The big belt killer seems to be heat. If your belt case filter is dirty or otherwise clogged, it will kill a belt in a short period. Maybe the belt side angle doesn't match the variator sheave angle well and it's stressing the belt in a smaller surface area than a stock belt. Always check the CVT filter when changing oil. |
![]() LXV 150 3v ie. Midnight Blue (Sold) Now Honda Zoomer X
Posts: 4131 Location: Kingdom of Lanna |
az_slynch wrote: Maybe the belt side angle doesn't match the variator sheave angle well The belt is the picture above looks like a GT200 belt. |
![]() Weird 80's Vespas & Cool Vintage Lambrettas
Posts: 15090 Location: The state of insanity, SoCal |
I've never had good luck with the polini transmission stuff. the rollers wear quickly and the belts besides their smaller displacement ones tend to have really short intervals as well.
for the 250/300's I'd only trust malossi. |
az_slynch wrote: Always check the CVT filter when changing oil. |
![]() UTC
Ss180, pv125, LML, LML NV, gt200, gts 300, gilera runner 180, italjet dragster 180, Apé ae3t, lx150, et8, gilera fuoco 500
Posts: 12 Location: Jhb South Africa |
![]() Ss180, pv125, LML, LML NV, gt200, gts 300, gilera runner 180, italjet dragster 180, Apé ae3t, lx150, et8, gilera fuoco 500
Those belts have a short life because of the extreme diameter the Variator moves out to. The performance on that Variator is insane, but at high top speeds the belt rubs on the casing on the bottom, by the sump. This leads to short life.
I have personally had them break on 3x different highly tuned bikes at around the 3000km mark, which is even less than what was quoted to you. Having said that, the bikes were routinely sitting at 140-150km/h for 20km intervals. In my opinion, a good compromise is the new BGM Variator kit, which uses the same principle as the polini Evo but isn't as aggressive. It will perform stronger than the polini 9 roller, but not as strong as the Evo. I have fitted about 6x BGM kits now and they seem to perform well. |
Moovers Speedshop wrote: Those belts have a short life because of the extreme diameter the Variator moves out to. The performance on that Variator is insane, but at high top speeds the belt rubs on the casing on the bottom, by the sump. This leads to short life. I have personally had them break on 3x different highly tuned bikes at around the 3000km mark, which is even less than what was quoted to you. Having said that, the bikes were routinely sitting at 140-150km/h for 20km intervals. In my opinion, a good compromise is the new BGM Variator kit, which uses the same principle as the polini Evo but isn't as aggressive. It will perform stronger than the polini 9 roller, but not as strong as the Evo. I have fitted about 6x BGM kits now and they seem to perform well. |
![]() UTC
Lars_Danner wrote: What kind of belly life are you seeing on the BGM? I really need about 6,000 miles. |
