Wildwood 5303 wrote:
Im guessing you didn't have problems.Everyone on here said take if off.
If the canister gets gas in it. I'm told causes all sorts of problems.
All the problems I had are gone.
You don't have to guess. I said I didn't have any problems with the evap system on my BV. Actually, I have owned 8 Piaggio and Vespa scooters with an evap system. Never had any trouble with any of them that could be traced to the evap system and I never disconnected the system on any of them. On the other hand, if your evap system WAS causing you problems and disconnecting it solved your problem - more power to you.
