Posts: 2116 Location: Oceanside, CA |
I noticed an abraded section of my positive battery cable housing. I don't think it's a critter related issue. It looks to be the outer sheath, but wanted to see if anyone thought a replacement was urgent. Thanks!
Posts: 46115 Location: Pleasant Hill, CA |
Get some self-amalgamating tape (a.k.a. rescue tape) and cut about a 6" length. Stretch it a bit a few times (this helps it adhere to itself) and then wrap it around. That'll make a waterproof insulating layer that'll stop any moisture or humidity corroding the wire.
Positive
jimc wrote: Get some self-amalgamating tape (a.k.a. rescue tape) and cut about a 6" length. Seems like good tape to have on hand. |
jimc wrote: Get some self-amalgamating tape (a.k.a. rescue tape) and cut about a 6" length. Stretch it a bit a few times (this helps it adhere to itself) and then wrap it around. That'll make a waterproof insulating layer that'll stop any moisture or humidity corroding the wire. https://www.amazon.com/dp/B00AEBKYPG |
Can you see what it's rubbing on? After you repair, it'd be a good idea to zip tie the cable to keep it away from whatever is chafing.
Positive
2006 Vespa GTS250ie, 2004 Vespa ET4, 2022 Royal Enfield Himalayan, 2001 Kawasaki W650, 2023 Honda Trail 125.
Posts: 2491 Location: Central Pennsylvania |
VESPAsfw3 wrote: Rescue tape. Never heard of it. |
Posts: 23427 Location: Harriman, Tennessee, Tn |
jess wrote: Stretchy, and sticks to itself but nothing else. It's amazing. |
Posts: 11696 Location: Hermit Kingdom |
old as dirt wrote: us old Air force flight line guys call it F4 tape, you can get it in various colors and it almost always has a stripe down the middle which goes to the outside when wrapping BTW. |
