@norman avatar
1978 MotoVespa 160GT, 2009 LML Star 2T (Stella), 1961 Lambretta S2
@norman avatar
Mine are cattle-trucked! Anyone know if they're the same as the PX125 type, or some weird LML exclusive?
@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
'74 50s x3 '87 PK125XL '92 PK50XLS Plurimatic - & - '58 AllState '68 Sprint '66(?) Super125 '72 DanMotor Super150 and '04 Bajaj LML hybrid
Huh, learn something new every day if you're paying sttention! Thanks for clearing that up for me, I was trying to imagne any possible connection & soon just gave up
I think Vespa 150 mounts fit according to this: https://www.scootermercato.com/Scooter-Parts/Buffer/SPRINTBUFFERS but have no hands on experience. If you've removed the old ones, post up a picture
⚠️ Last edited by V oodoo on UTC; edited 2 times
@garncarz avatar
@garncarz avatar
I work for a Brit firm and hear that stuff daily. Typically, I end up googling it and feeling stupid.
@norman avatar
@norman avatar
Thanks! The list shown on that page also includes the P-range, so I guess that means they're the same across most models, including LML.
@chandlerman avatar
Lucky
281 Days Since Last Explosion
Lucky
@chandlerman avatar
@norman avatar
@norman avatar
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Those should work, too.
@norman avatar
@norman avatar
Great! The LML originals have lasted 14 years (but only around 5k miles at a guess) and have now pretty much disintegrated. I'll be back with more bad language when I'm trying to fit the replacements
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Do some searching here for motor mount/buffer replacement unless you're a masochist.
If you have a piece of threaded rod and some large fender washers, you can use those to install the new mounts.
Opinions vary on how best to remove mounts.
The first time I tried to remove my Stella mounts, they were completely frozen into the tubes by rust. I wound up cutting the mounting bolt to get the motor out, then getting progressively more violent from there. Hopefully you won't have to do anything that drastic, though.
@orwell84 avatar
@orwell84 avatar
I recently did this job on my 200 using a heat gun, PB blaster, threaded rod and a few blunt instruments of opportunity.
The hardest part was getting the new ones in. Cleaned out and greased the case tube and used a file to put a bevel on the rubber to help it ease into the case. A little poking with a big punch and flat blade screwdriver to get the leading edges of the rubber into the case as I tightened the threaded rod. After that, they go right in.
@norman avatar
@norman avatar
Thanks for the tips guys. I think I also read that compressing the rubber with cable ties then putting them in the freezer also helps.
@orwell84 avatar
@orwell84 avatar
That's a good one.
GL150
GL150
The instructions on the BGM mounts that I've just fitted said to coat them in talc and tap them in with a mallet, it worked way better than I expected.
@norman avatar
@norman avatar
I've ordered the same. I've a feeling that removing the originals will be the more challenging part of the operation.
@hibbert avatar
Vespa
@hibbert avatar
Vespa
One of my least favorite jobs but talc might have made it different let us know how it goes.
I put Clauss mounts in Bear and it was ridiculously simple.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
I used the same mounts in my LML, easy install.
parallelogramerist
parallelogramerist
From what i remember to remove the Stella engine mounts from the swing arm..
You have to first grind out the swedge that's in the main tube. Use a propane torch and get the steel center tube good and hot until the rubber starts smoking and popping. Then twist it out with a pair of channel locks. To remove the rubber from the swingarm, get the aluminum good and hot with the torch. Then jam a screwdriver between the rubber and the aluminum and squirt some wd40 in there. Then pry the whole rubber portion out. It's never taken me more than a few minutes to remove both sides.
@norman avatar
@norman avatar
Stupid question, but what's a swedge?
⚠️ Last edited by norman on UTC; edited 1 time
@roland87 avatar
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
@roland87 avatar
IMHO absolutely easy job. Not need heating or freezing.
I mounted it on LML 125cc reed engine without any problems. I mounted it on my P150X.
And this also will fit.
So any P/PX 80-150cc will fit on to LML. Two piece type is easy for mounting.
But before mount it on case better to check how it fit to the chassis. I was need to grind down metal tubes few times.
parallelogramerist
parallelogramerist
It's those 4 indentations that are peened into the long hollow tube. It crimping the metal washer to the tube.
@roland87 avatar
@roland87 avatar
You need to grind down tube(red) and then take off spacer(green).
@norman avatar
@norman avatar
We will not be beaten!
@norman avatar
@norman avatar
Well, that's a job i hope I won't need to do again for a while!
I used a combination of the various methods previously mentioned. Difficult to say which was the most successful, but I'd probably go with the G-clamp against the central cut-out section of the swingarm. A few turns of that forced the metal tube out just enough to be able to get some molegrips on it so that I could wrestle it out. The (already-butchered) rubbers came out easily afterwards.
Fitting the new mounts was fairly straightforward. The larger side needed a few good whacks with The Persuader whereas the smaller side went almost all the way in with just a good push of the fingers. I used a threaded rod and washers to pull the two sides together. One thing to mention is that I found BGM's advise to use talc to be completely useless. A light smearing of tyre soap set the mounts on their merry way instead.
Job's a good 'un
Job's a good 'un
Job's a good, er, two
Now the real work can begin ...
@roland87 avatar
@roland87 avatar
roland87 wrote:
Now I can confidently say that this is crap. Indian LML crap.
This is how it look after near 4000 km.
[ Time: 0.0191s ][ Queries: 4 (0.0052s) ][ live ][ 327 ][ ThingOne ]
