@vsteve49 avatar
2005 PX 150, 2008 LX 150 2022 Sei Giorni., 2016 Sprint 3vie
@vsteve49 avatar
I'm going with the City grips 2 for my 2016 Sprint 3vie. It has 110/70X 12 on it now. Can I go to a 130/70X12 ? Any advantage or disadvantages? Do most motorcycle shops know how to change Vespa tires or is a dealer recommended?
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
The new tire would be 28mm taller and 20 mm wider.
Does your bike have clearance for that? Grab a measuring tape. If yes, yes. If no, no.
I would assume the answer is no.
You would also need to consider what the maximum size tire width your rim is designed for account for.
Fun fact: It could make your speedometer indicate slower than your actual speed by about 5%, so given that the speedometers on many Vespe are 5-10% exaggerated, you might actually get a more accurate reading.
You might be able to go over bumps better, might have slightly worse handling, personally I don't even think it would fit so I think the whole thing is a moot point.
Tire size calculator tool is your friend: https://tiresize.com/calculator/
@buggsy avatar
@buggsy avatar
Just fitted these to a GTS, front 120/70-12 58P & Rear 140/70-12 65P Continental Conti Twist, But as adri says measure first and more to the point make sure the dealer can balance themπŸ˜‰πŸ‘.
@greasy125 avatar
@greasy125 avatar
in the back you can go to a 130, up front I think it rubs. also, the wider tire in the front makes the steering feel slow and clunky.
@vsteve49 avatar
@vsteve49 avatar
Thanks for the info, I think I'll stick with the original size.πŸ‘πŸ»
What did you do when your three other Vespas needed tires? The Primavera is pretty much like the other two modern Vespas you own.
@vsteve49 avatar
@vsteve49 avatar
This is the first time I've had tire questions. The tires on my Sprint seem to be mushy. They are Savas and I check them for the proper psi, but to me they don't perform as well as my other Vespas.
@greasy125 avatar
@greasy125 avatar
it's because they are Savas and Savas are hot garbage.
@vsteve49 avatar
@vsteve49 avatar
Thanks I'm sure I'll notice a big improvement with city grips
@vsteve49 avatar
@vsteve49 avatar
The tire dealer I called said that he can't get the City grip 2 in the 110X70X12 for the front tire on my 2016 Sprint 150. But he did say that he could get a 110X90X12. Does anybody know if that will fit ok? He seemed to think that it would, I not the best at tire sizes.
just google the 110/70-12 and found 2 suppliers that have them instock. j&p cycles for $90 and steady garage $125. I am sure there are more folks have them as well.
@vsteve49 avatar
@vsteve49 avatar
Checked J&P out of stock on the 110x70x12. Cycle gear online says they have them, but when I called they said never carried them.
@greasy125 avatar
@greasy125 avatar
90 is fairly tall, I'd strongly recommend the stock size.
ebay and amazon are other options for getting ahold of one in the right size.
I double checked and its clearly says in stock[/url]
@vsteve49 avatar
@vsteve49 avatar
Thanks for the replies, I'll hunt down the proper size.
@wbdvt avatar
@wbdvt avatar
I bought a CG2 110/70-12 from Cycle Gear and it was delivered to me on Monday so they do have them.
I didn't need the back tire as that is the same as the front tire on my GTS 250 and I had 2 of them here.
[ Time: 0.0150s ][ Queries: 4 (0.0051s) ][ live ][ 328 ][ ThingOne ]
