2016 vespa gts 300
2016 vespa gts 300
Hi. First post. Im a newbie. Thanks for accepting.
Just want to ask how many relays in the front does have gts 300 model 2016.
I want to fix my rad fan. Its always on whenever you switch the key to on.
2016 vespa gts 300
2016 vespa gts 300
Just want to add. What socket is this for
@wbdvt avatar
@wbdvt avatar
I believe the fan relay is the one on the right with the Red, Gray, Black/Green and Blue/Yellow wires.
The contact is across terminals 30 and 87. With relay removed, test for continuity across those points. Should be infinite.
The second pic on the plug is for options such as an alarm system.
Report back on what you find.
Welcome to MV!
[ Time: 0.0103s ][ Queries: 4 (0.0022s) ][ live ][ 343 ][ ThingOne ]
