@michaelryerson avatar
'77 P200e (Maggie May)
Darnedest thing. Suddenly my engine side cowl latch is so stiff I very nearly can't open nor close it. Weather-stripping is straight, frame is not distorted. Tell me I'm not going to have to pull my gas tank. Please.
@hec_in_omaha avatar
1980 P125X US Spec
1980 P125X US Spec
Geez that's a tough one. I'm afraid you will need to pull the tank and have a look. I think a wire/harness or control cable found it's way between the the tension spring coils or got caught up on the ring terminal ground connection. This would prevent the spring from compressing and not allow you to pull and rotate the cowl latch.
My two cents.
Good luck
Hec
Engine Side Cowl spring behind wire harness on right side.
Thanks Hec, that's what I was afraid of.
1980 P125X US Spec
1980 P125X US Spec
No problem. Try this. Pull the protective sheath that covers the selector box cables almost all the way out. Tug and pull on the selector box control cables too. Maybe if your lucky, and have lead a clean life, things will loosen up for you.
Hec
@roland87 avatar
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
@roland87 avatar
Why? It is not very hard job on P.
I've always been pretty lucky. The clean life thing may trip me up though. I'll monkey with the selector box cables tonight or tomorrow.
⚠️ Last edited by MichaelRyerson on UTC; edited 1 time
No roland, you're right. I should just embrace the life. Thanks.
1980 P125X US Spec
1980 P125X US Spec
Try pulling and pushing on everything coming out of this grommet before you remove the fuel tank. There is a lot of stuff for the latch to get hung up on there.
Hec
Tug and pull on everything coming out of this grommet.
Will do, Hec. Will probably be pretty methodical about it. I'm going to want to know what it is and how it came to foul that latch. Maybe a Saturday morning job. By the way, congratulations on your very sano scoot. And I thought mine was pretty clean.
1980 P125X US Spec
1980 P125X US Spec
It's a little premature to call it a scoot. I am still in the reassembly process. Right now you could call it a work in progress!
Hec
W.I.P.
W.I.P.
[ Time: 0.0113s ][ Queries: 4 (0.0021s) ][ live ][ 313 ][ ThingOne ]
