@mr-blazer avatar
Primavera 150; SS180
@mr-blazer avatar
After spending the last year trying to dial in my motor, I gave up and decided to tear it down and rebuild it. It has three problems:
1 Kickstarter locks about every other kick.
2 Clutch shaft leaks
3 And now, my head (below):
@mr-blazer avatar
@mr-blazer avatar
I want to go with a paper gasket and replace that dumb o-ring. At first I was thinking of filling in the groove and broken part with JB weld, but I thought that it might not stand up to the heat/cooling cycle.
So now I'm thinking to just repair the cracked piece with JB weld and fill in the groove with some fuel-tolerant gasket sealer.
I don't know yet.
@greasy125 avatar
@greasy125 avatar
I think you'll still be chasing your ass on a repair with that head.
I'd plunk down the coin for a new one and cross that shit right off my list and not look back.
@chandlerman avatar
Lucky
49 Days Since Last Explosion
Lucky
@chandlerman avatar
Agreed.
Also, wtf happened to that stud hole? It looks like it got drilled twice at some point, which makes me wonder what else is going on from a Bad Touch perspective with your motor.
@mr-blazer avatar
@mr-blazer avatar
Dude, I don't know. This was supposedly rebuilt by some Vespa performance guru but, as usual, if you want something done right . . .
I buy old cars (and Vespas) and sellers seem to fall into three categories:
1. The cheap rat who doesn't want to spend what's needed to do it right.
2. The dude who does everything half-assed but thinks it's good enough and will hold up.
3. The guy who just doesn't know what tf he's doing.
I think my dude is a combo of 2 & 3. Very disappointing as this was sold to me as "just rebuilt", "like new", etc., etc. Bought it here too.
Finally, I'd love to buy a new head but so far I can't find one.
@mr-blazer avatar
@mr-blazer avatar
chandlerman wrote:
Agreed.
This is a SS180. Would a P200 head work? They look awfully close. Different part #s though.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Until you replace that head, you're never going to run right. Did you put it through a parts cleaner to get it so clean?
Check the kickstart quadrant isn't bent if it locks up. If it's not, when you open the cases, make sure the rubber buffers aren't out of place. If one of them is, it can jam things up from time to time.
And, yeah, the average scooterist is cheap af and has no idea what they're doing mechanically.
@oopsclunkthud avatar
3:5
The head you have is a modified P200 head.
the stud placement of the SS180 and P200 are not the same, that's why one of the holes on yours is modified to be peanut shape.
@mr-blazer avatar
@mr-blazer avatar
Ha, the dishwasher.
Thanks so much for this. I'm just getting started. I'm sure there's much more to come.
VNB VSC VMA VSX - o9c vbc vmb
Man those heads are spendy when they come up. Godspeed.
@mr-blazer avatar
@mr-blazer avatar
Update: Scooterwest just responded and said that "in theory" the VSX head should fit a VSC.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
mr-blazer wrote:
Ha, the dishwasher.
Waaaaaay ahead of you... Razz emoticon
Yes.
See OTC's comment above.
@greasy125 avatar
@greasy125 avatar
somebody obviously knew what they were doing in that the head is drilled, tapped and profiled, it's just sloppy work-- the bowl doesn't look finished nicely, which wtf? that takes like two seconds when it's chucked up. and the break obviously happened somewhere along the line *before* being assembled, so somebody just slammed it together and said "ship it!".
besides modifying a P200 head, is there another that works or could be made to work? GS maybe?
3:5
and if going to all that work then may as well recess it into the bore to locate it and tighten up the squish.
@mr-blazer avatar
@mr-blazer avatar
Back on the bench. At least it looks good, even if it doesn't run.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Do you have a fixture to hold a head level or a process to recess with an offset sparkplug? I was looking into that on a P200 head, however it was cost prohibitive with setup etc. Ended up purchasing a center mount spark plug so I could chuck it up in a lathe using a piston stop.
@velasquez avatar
1978 P150X; 1982 P200e
@velasquez avatar
Clean looking SS!!! Is that a vespatronic ignition?
@mr-blazer avatar
@mr-blazer avatar
Yes it is.
3:5
I'll be building a jig like this as soon as my lathe is up and running.
Cylinder Stud Patterns (Post 2306188)
2007 Stella 225
2007 Stella 225
That's the type of fixture I had in mind, never worked through what needed to be done for leveling, locating etc.
3:5
general procedure is to:
1. clamp the head face down on a mill and spot face each of the stud bosses.
2. the fixture then holds the head by the stud bosses to present the face for any reprofiling.
150 Super 1978
150 Super 1978
Replace the Xmas tree and/or the small kickstart gear.
Clutch shaft leaks
There's an O-ring at the the clutch actuator arm where it goes into the clutch lid.
You can see here how it's installed in its groove.
External inline image provided by member with no explanatory text[/quote]
@mr-blazer avatar
@mr-blazer avatar
Thanks so much for this. I'm not there yet but, believe me, I am taking everything in.
@mr-blazer avatar
@mr-blazer avatar
The clutch arm was bent and was binding. It's not totally clear from the pic, but it's not seating true so the o ring isn't seating symmetrically.
@mr-blazer avatar
@mr-blazer avatar
Clutch cover is now rebuilt and installed.
So, noob question: Should I be able to actuate the clutch by pulling on the clutch arm?
When the clutch cover was off, the arm worked fine. But installed, it feels like the clutch is locked up - I can't compress it.
3:5
you would need about a 6" lever arm added to be able to move it by hand
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
This.
Clamp a pair of vice grips on the lever and you should be able to move it and feel it (dis)engaging.
@mr-blazer avatar
@mr-blazer avatar
Ok, sorry for neglecting this thread but everything went together smoothly and my issues appear to be solved. Here are a couple of in process pix:
New head - a VSX head. Weirdly (or not), the combustion chamber was actually the worst finished part of the head. I hand polished it but I wasn't gonna get everything, so this is what I wound up with:
@mr-blazer avatar
@mr-blazer avatar
Ok, so this pig runs. No vid so you're just gonna have to take my word for it. Now to get it off the stand and adjust everything. Don't know if this is the easy part or the hard part. Thanks to everybody for their tips.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Glad to hear it!
What's the story with that airbox setup? I've never seen that before, but it looks interesting.
@mr-blazer avatar
@mr-blazer avatar
It's stock. It just needed that rubber bellows thingie installed. I didn't do it yet because I would just have to take it all apart again if I have to re-jet it.
@subetherbass avatar
chandlerman wrote:
Glad to hear it!
It's a SS180 airbox setup
@mr-blazer avatar
@mr-blazer avatar
On an SS180, of all things!
@mr-blazer avatar
@mr-blazer avatar
Ok, I thought I would post a little cheesecake to wrap this up. I think I'm pretty close with jetting with:
Idle: 55/100
Tube: BE2
AC: 150
Main: 135
My plug B8ES is still pretty black so I may try a B7ES.
[ Time: 0.0157s ][ Queries: 4 (0.0053s) ][ live ][ 313 ][ ThingOne ]
