GTS 350
GTS 350
Bought this vespa 2 months ago. Has 2000 miles on it. It wont start anymore. Horn blares when the key switch is turned. Engine does not turn over. I disconnected and reconnected the battery. That did not help.
Any ideas on what I should try?
@rallygeek avatar
@rallygeek avatar
Have you turned off the alarm? The other option is to disconnect it. You can access it from behind the left hand knee pad.
GTS 350
GTS 350
I have used the remote to toggle the alarm. It didn't make difference . I will go try to disconnect it. thank you for the note.
2019 GTS300 Supertech E3 59,000km
Have you replaced the battery in the remote?
GTS 350
GTS 350
just see a bunch of wire bundles and a connector or two under the left knee pad cover. Not keen on randomly unplugging. May just give up and tow to the shop.
[ Time: 0.0082s ][ Queries: 3 (0.0016s) ][ live ][ 313 ][ ThingOne ]
