@scrumpadelic avatar
73 Sprint w/ P210
73 Sprint w/ P210
73 Sprint with OEM speedo whose needle is stuck on 20 km/h. It's off the scooter so I know it's not the cable at fault. I can zero it using the reverse drill method but it "creeps" back up or if I give it a little shake it moves about and stops on 20. Maybe suttin's broken?
I know I have a couple options: Speedo King or buy a new one but before I do one of those, maybe there's something simple I can do? I've got some dry lube with teflon but I don't want to just start blasting it in there and making everything a mess... and where do I even spray it...in where the bulb goes? Up the cable hole?
Probably a lost cause but maybe worth a shot...
Happy new year scooter nerds.
1980 Bajaj
1980 Bajaj
Mine was stuck too. 1980 Bajaj (early 70s Sprint) - it was that the needle would touch the display under it. The casing/enclosure is weak and if you over tighten the long bolt holding it down to the headlight assembly, it would result in the above. I bent the speedo enclosure inward
73 Sprint w/ P210
73 Sprint w/ P210
Oh cool I'll check that out. Cheers.
73 Sprint w/ P210
73 Sprint w/ P210
Nope. Plenty of room below the needle
@waspmike avatar
@waspmike avatar
Depends on how handy you are? You can buy a repair kit.https://klewerstore.blogspot.com/2012/09/new-vespa-speedometer-vbb-gt-gl-sprint.html
So logically you can work the bezel (Aluminium bit) until it pops off.
Two screwdrivers under the pointer it will pop off and then lube the shaft.
73 Sprint w/ P210
73 Sprint w/ P210
Oh yeah… forgot that third option… SIP sells those plus the lens (mine has a small crack as well).
Main takeaway is… if I do take it apart, I'm lubing the shaft. Good to know. And taking the whole thing apart is the only way of accomplishing this?
@waspmike avatar
@waspmike avatar
The Aussie 2nd engineer told me on one ocasion you have two choices "Fix it or, fuck it"
In your case it is broken so do something, eh!
Are the Cannucks still top of the league ?
73 Sprint w/ P210
73 Sprint w/ P210
Thought I'd fix it. Guess I'll fuck it.
Canucks for the league!!!
@subetherbass avatar
Put lots of layers of masking tape around the bezel (so WHEN you slip with screwdriver you don't scratch the bezel).
Put glass side down and add packing under glass etc so you can put weight on it and keep it in position plus it won't put too much stress on glass (for a round speedo i used the roll of masking tape as it fit snugly).
Get a thin flat screwdriver & slowly start prising the back lip of bezel out, keep the gap nice n even so you're not stretching the bezel nor making bends in it... go round and round heaps of times so it "stretches" & eventually can be slid off...
Remove bezel & glass.
Do whatever you need to fix needle. (For the purpose of this story: change mph to km/h so it complies to local ADR regs)
Slide bezel & glass back on.
Now Ensure packing in big enough so front lip of bezel is supported.
Get a wee hammer & gently tap-tap-tap to rebend back lip of bezel over again till it's nice n tight.
Give completed work back to boss... then find out there are 3 more to do, as the glow-in-the-dark needle tips need to be repainted...
repeat...
... Then find out they were irreplaceable original Porsche 356 Gauges that you have been playing with, not just cheap knockoffs...
Cool... on with the upholstery...
... Then find out they were irreplaceable original Porsche 356 Gauges that you have been playing with, not just cheap knockoffs... Cool... on with the upholstery...
73 Sprint w/ P210
73 Sprint w/ P210
SubEtherBASS wrote:
Put lots of layers of masking tape around the bezel….
Amazing. Thanks.
I might just give it a go. Nothing to lose if I was going to get a new one anyway.
@waspmike avatar
@waspmike avatar
My my Aussie 2nd meant All those years ago.
[ Time: 0.0168s ][ Queries: 4 (0.0070s) ][ live ][ 313 ][ ThingOne ]
