Vespa 2015 primavera
Can Vespa Throttle Body with ecu upgrade to Throttle Body without ecu +plug-in ecu
Why? And which Vespa
If you want a bigger throttle body on a gts 300 then I know you can get the 38mm version from a Piaggio Beverly 350 and use that. There are some on vespaforum.de who have done this.
For the GTS HPE if you want to tweak the engine mapping the you can use something like
Malossi Forcemaster 3 https://www.malossistore.com/en/it/force-master-3-electronic-controller-for-injection-vehicles-vespa-gts-hpe-300-ie-4t-lc-euro-5-2021-2022-md31m-5519335-vehpe30021-M-P
TFC Smart ECU https://www.tfc-drag-racing.com.tw/en/product_description.php?PNo=763
and for a 125/150 Sprint / Primavera
Malossi Forcemaster 2
aRacer https://www.aracer-speedtek.com/faq.php?lang=en&tb=1&cid=3
here's an example of replacing the standard combined throttle body / ecu in a GTS with separate
https://www.instagram.com/reel/CmiNB7oBtXd/
[ Time: 0.0173s ][ Queries: 3 (0.0083s) ][ live ][ 343 ][ ThingOne ]
