So I have a 2001 Vespa ET4 150 with 1000 miles. Ran pretty will when I bought it, little bit of stuttering and slow acceleration off the line but not bad. This it started to show some problems so I cleaned the carb and the float bowl gasket was shot so used some liquid gasket to get by until i found one. Turns out nobody makes parts or gaskets for the Walbro carb anymore so I went to scooterwesy and bought a brand new Kehien 2600a carb. Was supposed to be a perfect drop it but that was not the case for me. Trouble off the bat with starting and running. Stranded my girlfriend half a dozen times on her way to university. So I did a full work up, new spark plug, new battery, new belt and rollers, new petcock and fuel line, new airflter. Did an EVAP system delete and replaced all the vac lines. Still refuses to run, will only start and stay running with 1/4+ throttle applied and runs terribly, sound like it chugs and blows a touch of black smoke(I'll attach a video) will not idle at all. Out of curiosity I threw in the old Walbro carb and of course starts right up and runs pretty dang good (still a bit slow and stutter off the line) once up to speed 15MPH+ it runs and accelerates wonderfully. Also it's not a manifold problem, I sprayed it with carb cleaner and no idle variations. So what could be the problem with the new carb? Are the jets a different/wrong size? Thanks for any help!
https://youtube.com/shorts/gdp8yp_a8ig?si=LDe_p6ePMwTnqGyV
