vespa pk50s
vespa pk50s
Hello 2t vespa fans. I have a pk 50 with about 5000 kilometers. Whenever I ride uphill, or when the is a lot of weight on the engine and gearbox (mostly on 4th gear) the gear fails for half a second or less. It is like pulling the cluch really fast while driving. Any opinions about the problem? Is it some broken gear teeth? (info I have a bad clutch)
@ccsp03 avatar
Rally 180, TS 125, PX 150 and a lot of smallies
@ccsp03 avatar
Sounds to me your shifting cross needs to be replaced.
@mjrally avatar
@mjrally avatar
Shifting cross and possibly worn 4th gear. It will require the cases to be opened up.
@safis avatar
@safis avatar
Maybe the gear cables are too tight so they put pressure on the gear selector while sitting on the scoot…
@kudu avatar
1979 P125X, 1983 P125X America
@kudu avatar
Having experienced similar issues, I concur with SaFiS on this. Also because time and again Vespas have proven to me that on a standard scooter the simplest possible problem is the most likely one...
@chandlerman avatar
Innovator
56 Days Since Last Explosion
Innovator
@chandlerman avatar
Even if it was originally the gear cables, now that it's bashed the cruciform and gears around for a while, the cruciform and possibly gear will need to be replaced in any case.
@mjrally avatar
@mjrally avatar
Why does it only happen uphill or with weight on it? Wouldn't it show more often if it was just a cable issue?
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
my smallframe did this. in one case it was because i had tuned it and did not get a strong enough spring in the selector. i think the other time was cables. if you don't get the pressure on the selector it can pop out. cables are a likely source, well worth checking.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
Advice I was given to keep the selector in place was to keep the standard spring, but add an extra ball bearing. I did that on the Smallstate and it's never had problems staying in gear.
The other piece of advice from Matt & Dave was to assemble the whole thing in a clear plastic bag so when (it's a "when," not an "if") a ball bearing or the spring go flying, you won't lose them.
[ Time: 0.0102s ][ Queries: 3 (0.0034s) ][ live ][ 339 ][ ThingOne ]
