Greetings,
I bought my scooter in June 2021, I use it daily. I took it to the service for a 500 km check, it was alright. It is now at 6000 km and I went to the service for its first periodic maintenance. After the technical guy did the generals such as oil change, filters etc., he said that the clutch drum is "burned" - the surface deteriorated and needed to be replaced. I am not sure if this is necessary or not. I know that the clutch lining wears out over time and is changed at about 10-12,000 km, but I do not know in what situations the clutch drum should be changed. If you have any experience on the subject, I would be very grateful if you share it.
Vespa Primavera 150 Model Year 2012 6000km
Clutch Drum Part No: 1A004103
WS
