benedicto15 wrote:
Thanks a lot for the info!! I ordered a racing sip exhaust which is most likely more powerful than the sip 3.1. Double checked SIP site and figured i can just change the exhaust manifold to fit it on the 200 engine. As for the ignition timing, yes already ordered the needed tools! Are you using a 24 or 26mm carb?
That's a great looking bike! I like that a lot.
I run a 24mm carb on my P200, but it's set up as a strong touring motor, so lots of torque, wide power band, autolube, and cool running.
I run PWK's on my performance builds.
With the tuned pipe, you need to be very careful about getting the jetting right and also should do a pressure test (again, search on here) to make sure you have no air leaks.
I blew up multiple top ends when I was getting started in tuning because of air leaks and just generally not knowing what I was doing.
