Jlew2000 wrote:
Hi there, I have a 2000 Vespa px 125 with a 150cc top end and a sterling exhaust. I had a dellorto PHBH 28 on for a while but seemed too big so decided to put a PHBH 26 on instead. it runs and rides but doesn't seem to run as sweet as the 28 did. Any idea on what jets I require for either the 26 or 28?
Many thanks
Any advice much appreciated.
Jack
That carb is huge, do what the others suggested and stick the 20mm back on. That sterling exhaust is nothing but a noise maker too and wont benefit a standard 150 barrel. Stick a 20mm back on with a road 2.0 exhaust jetted four points up on main over standard. This is the standard jetting for a UK PX 150 recommended by allstyles in hampshire. So with a road 2.0, likely going up to a 120 main if using the combo listed below.
PX 150 (VLX1T)
CARBURETOR: DELLORTO SI 20/20 D
VENTURI SIZE: 20 mm
MAIN JET: 116
PILOT JET: 45/160
THROTTLE VALVE: 6823.01
MIXER TUBE: BE 3
AIR CORRECTION JET 150
STARTER JET: 60/100
