Vespa s
Vespa s
Hi all I was driving my Vespa S today to the petrol station fuel was low. The scooter just cut out completely and lost electricity no head light or electric start. Any ideas on what this could possibly be.
2019 GTS 300 HPE w Malossi
any lights on the dashboard? backlight on the speedo?
@slowpoke avatar
1952 allstate (early), 1958 allstate, 2009 S150, 2001 ET2
@slowpoke avatar
Did you make sure the kill switch is not engaged? Hold the brake and hit the start button again. Let us know what happened when you did those.
Vespa s
Vespa s
I tried that no power at all. No lights on at all?
battery posts clean and tight?
@jkj-fz6 avatar
@jkj-fz6 avatar
Check that the battery connections are clean and tight.
Vespa s
Vespa s
Done this and disconnected the battery and put it on charge to see if it was something to do with that and it was fine.
Check all fuses with a multimeter.
Check user manual for list of locations of all fuses (a couple may be separate to the main group ...)
@jkj-fz6 avatar
@jkj-fz6 avatar
Can you hear the starter relay click when you press the Start button?
What year and engine size is your Vespa S? And how old is the battery?
[ Time: 0.0113s ][ Queries: 3 (0.0020s) ][ live ][ 343 ][ ThingOne ]
