2012 s150 ie, 1997 px150
good day guys. i just recently opened up my 24mm carb and i am wondering what jettings are reccomended.
my current jetting:
idle jet: 50/100
air corrector: 120
mixer: be4
main jet: 101
current setup is a px150 with a polini cast iron 177 kit(no port matching or what, srtaight bolt on install), sip road 2.0(will change to sip racing exhaust coming this month), 24mm carb.
at around 1/8 to 1/4 throttle i notice a little power loss during acceleration. idle also goes way up when engine is warm. any advice would be a big help.
@gickspeed avatar
@gickspeed avatar
Fates got a driver. Your main jet is too low. Start at a 125 and work down. I reckon you are at 116, give or take.
hello. thanks a lot for the response. i'll buy a main jet kit so i can test it out. how about the other components? should i just focus on the main jet first?
@gickspeed avatar
@gickspeed avatar
I take it you have a "G" carb?
yes it is a 24.24G.
@scooterist avatar
@scooterist avatar
I run 120-122 on my Malossis 166cc and 177cc. Malossi comes with a 115 main jet. Assuming that you have at least an exhaust box that should put you at a minimum of around 120 main jet. You can try the 125 main jet but I think is a hair too rich. I am running a BE3 and a 55 idler.
The idle going up when hot is an indication that the air/fuel mixture is a bit lean.
[ Time: 0.0087s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
