I recently changed the muffler on my PX-150e and just want to share my experience.
There are a couple of helpful videos on YouTube that show how to do this job. And it's relatively easy with a stock replacement part of the same dimensions. Can be done with basic tools and takes around one hour.
Steps
Remove the bolt that clamps the muffler to the exhaust port.
Slightly lift the back end of the scooter with a jack or block.
Detach the rear wheel from the hub and slide wheel backward.
Remove the long bolt that attaches the muffler to the frame.
Wiggle the old muffler until it comes off.
Reverse the steps to install the new muffler.
*Make sure the new muffler is firmly seated to the exhaust port before tightening the clamp. There should be around a 3cm overlap.
Result
The new muffler worked great, but I was a bit disappointed that the motor was just as loud as before. My PX seems to be louder than most, but apparently that has little to do with the muffler.
