@mjrally avatar
@mjrally avatar
It might have been discussed before but I'm not using the right search terms, but does anyone know ballpark how many points to adjust for a rotary motor vs reed with everything else being equal?
Jet Eye Master
Jet Eye Master
Reed will be richer but really depends on the details. Which reed block?
@mjrally avatar
@mjrally avatar
Basic LML Stella reed block vs Piaggio rotary
@108 avatar
V range 50s
@108 avatar
V range 50s
Wouldn't jetting be the same?
Cylinder/exhaust/timing hasn't changed…
Just the way the fuel and air is fed in is different.
Jet Eye Master
Jet Eye Master
For a totally stock set up on both, the reeds have less blow back, so would be leaner jetted for the same everything on low throttle but richer overall jetting at higher rpm.
I would expect the Stella to be more economical than the Vespa and still be slightly quicker. Having almost no experience of totally stock set ups, this is just what I expect.
Once kitted this situation completely changes for both.
@mjrally avatar
@mjrally avatar
Got any ballpark ideas for a middle of the road kit with a 24/24 carb and road 3.0? Just looking for a good place to start.
@chandlerman avatar
Innovator
99 Days Since Last Explosion
Innovator
@chandlerman avatar
140AC/BE4/130MJ is where I'd start with that. It may be rich, but shouldn't be lean.
@mjrally avatar
@mjrally avatar
So after some runs this morning, I'd say ballpark rotary uses 5-7 points LESS than the equivalent reed setup.
Jet Eye Master
Jet Eye Master
I'd go with AC120/BE3/135 and 55/120
Main jet is hopefully too big and will reduce.
[ Time: 0.0104s ][ Queries: 3 (0.0019s) ][ live ][ 341 ][ ThingOne ]
