My lights won't come on unless the key is in the park position … which is signal with something like a J in the ignition..
Any idea ??
Maybe a bad relay ?
Any idea ?? Maybe a bad relay ? |
Moving to NSM, as I don't think there will be a lot of response in General Discussion.
Anyone? |
Posts: 2772 Location: Philadelphia |
Will need lots of pics of the whole Ape to help…
Just kidding, I just love the Ape and wanna see lots of pictures. |
Pabs80 wrote: There you go Friday lol |
Posts: 5353 Location: Oceanside, CA |
Pabs80 wrote: My lights won't come on unless the key is in the park position … which is signal with something like a J in the ignition.. Any idea ?? Maybe a bad relay ? What's the story of the Ape? Had someone restore it for you? Built it yourself? Bought as is? Do you know anyone handy with electrical? |
P200, Stella, P150S, CH80
Posts: 106 Location: San Diego, California |
Go to Mondoape.com
That's the modern Vespa equivalent for Apes. Every single wiring diagram can be found there as well. Most of the posts are in Italian BUT if you use google chrome you can easily translate the entire web page with a single click. Cheers!
Positive
Thanks for the comments
And yes … they used to work … But it has been an ongoing issue since I got it … it used to work sometime or they would get brighter if I rev the engine … now they don't work at all I got it in fairly decent condition… I asked a local paint shop to paint it and I put some vinyl decals I don't know anything about electric … just very very basic things Like I installed a Stebel horn |
Posts: 10138 Location: Hustletown, TX |
It is typical to get brighter lights on rev.
I wonder if the key switch just had connection come loose? |
Posts: 10087 Location: seattle/athens |
Nice looking newer Ape! Is it 12V and does it have a battery? Are the lights switched by the ignition key or is there a separate switch? Did side markers & tail lights come on w/ ignition switch in P, but not the headlight when everything was working? Can you post up pics of front and back of your ignition switch?
Probably something simple like a loose power connection or a sketchy ground... |
Yes it is a 12v
And it has a fairly new battery … it starts right up and everything…. The lights switch with a separate switch … it goes from the switch to the ignition … The tail lights turn on when ingnition in park position All the lights turn on with when switch is in park … even the headlights and dashboard … but no dash board or headlights while running … only directional and break lights Could it be the light switch ?? How can I test it ?? Also the ignition in the back has a cover and not sure how to take it apart Also I'm assuming that the relay is wired correctly… cause it does make the starter work
"All the lights turn on with when switch is in park" So all your lights work and wires are connected to ignition switch OK...
But the separate headlight switch used to work fine, then intermittent, and now nothing at all? Yeah, sounds like that switch is whack. Post up a picture of it and the connections in back if you can. That relay is just for the heavy starter motor load, I believe it has nothing to do w/ your lights. |
1980 P125X US Spec
Posts: 614 Location: Beaver Lake, Nebraska USA |
Pabs80
Check all your electrical connections! Make sure wire terminals are not touching metal parts or the frame. I can see evidence of a wire grounding out in one of your pictures. Look closely at the metal housing near the wire. Look for signs like melted plastic or insulation, and dark burn marks on metal or plastic. Make sure all plastic wire connectors are pushed up so that wire terminals aren't exposed. Nice ride! Hec
Thank you so much for pointing out the grounding .
I would have never noticed !! So now I can fix it Here is the pic of the switch I ordered a new one … I hope that fix it. The switch should pop up if I push it from behind … right ?
1980 P125X US Spec
That electrical tape is also suspect. Remove it and see what lies underneath. You may find a poor wire splice there. Try this. Take a piece of wire with both ends stripped back of insulation. Shove one end of the wire into the center socket of the light switch wiring plug and the shove the other end into one of the outer sockets. Start the engine and see if your light turn on. Repeat the test using the other outer plug socket. If the light works then your switch is bad. I am guessing that the center socket provides power to the switch and one outer socket activates the low beam and the other activates the high beam.
Good luck! Hec
We sell modern APE PIAGGIO. The lights are connected to the switch in order to save battery. You can forget to turn the lights off and then you will have some problems. Best thing to do is to check and clean every connection in your unit.
Posts: 5175 Location: Veria, Greece |
Lights on the Ape 50 should run on AC while engine's running. Only the Parking position should run of the battery. What's with the white / black and white wires?? Are they connected together?? Seems like someone messed with the wiring. There's a chance the AC system / regulator is faulty so they decided to run the lights of the battery??
Maybe find someone who knows Apes / Vespa electrical systems. They're not rocket science but require some basic knowledge of how they work and of their quirks... |
Well I followed the advice .. I did the jumper and uncovered the electric tape
Nothing behind the electric tape … lol I don't even know why was there :/ Pics bellow I tried every combination with the jumper cable while I have the ape running and no lights came on … They do still work when in park position (ignition) It makes my head hurt 😔
1980 P125X US Spec
Pabs80 wrote: Well I followed the advice .. I did the jumper and uncovered the electric tape Nothing behind the electric tape … lol I don't even know why was there :/ Pics bellow I tried every combination with the jumper cable while I have the ape running and no lights came on … They do still work when in park position (ignition) It makes my head hurt 😔 You mentioned that the lights came on in park position. Did all lights come on to include the headlight? If they did, then it sure looks like you have an issue with the ignition key switch. Keep us posted! Hec |
Yes in park position the tail lights and headlight come on
They don't switch from high to low beam though Signal lights don't come on in park … not sure if this is relevant The switch in the pic is the only switch to turn the lights on … so if I disconnect that harnes for the switch I no longer can operate or and off … or did you mean measure in then lightbulb end of the wire ?? |
1980 P125X US Spec
Pabs80 wrote: Yes in park position the tail lights and headlight come on They don't switch from high to low beam though Signal lights don't come on in park … not sure if this is relevant The switch in the pic is the only switch to turn the lights on … so if I disconnect that harnes for the switch I no longer can operate or and off … or did you mean measure in then lightbulb end of the wire ?? Hec |
Find someone to work on it. The main lights run off the engine while it's running (AC powered) not the battery. There's probably a problem on the AC side, regulator is faulty, blown bulbs, etc. From your description the Parking position works as it should…
Yeah the problem is hard to find someone willing to work on it
:/ What regulates the ac power ?? Is that something I can replace ? There are not that many parts in this thing lol |
Look up the local scooter club in Tampa. I think they are called Tampa Two Stroke? I'm sure some of those people can help you. Electrical issues can be difficult to diagnose, especially from afar. Best of luck to you.
1980 P125X US Spec
Pabs80 wrote: Hec Engine not running in park … you can't start the engine in park position I am hoping it looks like this! https://www.scooterwest.com/ape-ignition-switch.html Hec
Update !!
I took the ignition switch and all cables seem good I tried to measure voltage at the head light and I got nothing … but not sure if I did right … the glass came apart … which was a bummer but I glued back together but give me time to inspect the light bulbs The head light bulk big one is fine … wire it directly to the battery and lit up I put it in park … the little light bulb came on …. But when I remove the big bulb the other one shut off… So it got me thinking …. Is there a possibility that there is something wrong with the little bulb that prevents the big one from getting power ? |
1980 P125X US Spec
Pabs80 wrote: Update !! I took the ignition switch and all cables seem good I tried to measure voltage at the head light and I got nothing … but not sure if I did right … the glass came apart … which was a bummer but I glued back together but give me time to inspect the light bulbs The head light bulk big one is fine … wire it directly to the battery and lit up I put it in park … the little light bulb came on …. But when I remove the big bulb the other one shut off… So it got me thinking …. Is there a possibility that there is something wrong with the little bulb that prevents the big one from getting power ? I checked here but the APE 50 TL1 manual had a wiring diagram for 6V. Don't know if it applies to yours. https://www.mondoape.com/mondoape/manuali-ape-50-tl1-tl6/ Hec |
I feel the more I know the less I know !! The light bulb works I connected it directly to the battery with some wires … it light up no problem !! I have followed te wires and I have not found any fuse :/ Maybe is hidden somewhere?? What's the stator lol and where is it ?? lol Wouldn't the stator power the directional They work no problem :/ |
