Gail wrote:
...and 5 minutes later it won't start
Can you elaborate more what happens when it won't start? It turns over and tries to start, but won't go? Or it just sits there dead?
Anything going on with the immobilizer light?
You said it will start if you jump it - like from a car battery and jumper cables? What if you charge the battery, then will it start again?
I'd expect a charged up battery to start the bike several times, even if the bike wasn't charging it in between. Maybe there's a short that's rapidly draining the battery but somehow not causing a fuse to blow.
