GL150, PX150, ET4, Stella Atomic Fireball w/ sidecar
Posts: 16 Location: South Florida |
I pulled my rear wheel to put a new tire on it and there wasn't a dust cover over the center retaining nut. Did they have one? If so, would anyone have one laying around. I've looked on line for one with no luck.
Posts: 1486 Location: Denver |
Here you go: https://www.ebay.com/itm/201525151015?epid=592936455&hash=item2eebd5c527:g:ghYAAOSwezVWxIOJ&amdata=enc%3AAQAIAAAA4CYtgECHqOuoSHrwswhA9hJDzGfbUFArDdexZHdiaXuVELHQNzUEUxqGKBVdAZHWcK545Q5WsjdrXjWbUxZR6%2FexR0CUzSW%2FFw6BfjqN0RPBcUmanbPsQ6yxFQYKopodD8G9ioRleFCYITIwRih28E2R%2BME%2F5KXZZk4dNCtDYlngAz%2BxWqFpLZ5pgFMo1hw1LJcRHcY1EmaCplQWs3yUNbhNWbTKCY7stcuH0DtmJkB%2BlIjArR5GLykw%2BKsbPMc9Pfbh1Yow9GrInTSbgrk4PqI2CKE5m01m4WP8ZjYlyIQJ%7Ctkp%3ABk9SR7CpxKmkYw Less than what you paid for coffee this morning.
atomic13 wrote: I pulled my rear wheel to put a new tire on it and there wasn't a dust cover over the center retaining nut. Did they have one? If so, would anyone have one laying around. I've looked on line for one with no luck. Here's another: https://scooterpartsco.com/et4-tires-and-wheels-c-3637_3640_3753/cover-for-rear-wheel-nut-194423-p-36469.html |
You torque that rear axle nut to 80 ftlbs +/-. Piaggio is the only scooter maker I have ran across that has this belt and suspender method to make sure the rear wheel doesn't fall off.
Abner_Bjorn wrote: You torque that rear axle nut to 80 ftlbs +/-. Piaggio is the only scooter maker I have ran across that has this belt and suspender method to make sure the rear wheel doesn't fall off. Crash bang wallop. How to straighten the steering column. 2nd ride after rebuild...wheel fell off.....went to hospital |
Posts: 12741 Location: Fond du Lac, Wisconsin |
Abner_Bjorn wrote: Less than what you paid for coffee this morning. If the OP hasn't rushed off to order, I can have a look in my parts box. If I do, it won't be shiny.... |
berto wrote: That's not a dust cover. It keeps that axle nut locked in place, with the help of the cotter pin. Here's another: https://scooterpartsco.com/et4-tires-and-wheels-c-3637_3640_3753/cover-for-rear-wheel-nut-194423-p-36469.html https://scooterpartsco.com/et4-tires-and-wheels-c-3637_3640_3753/rear-wheel-nut-cap-and-cotter-pin-kit-for-vespa-piaggio-p-37080.html |
Or are you looking for this?
https://www.scooterwest.com/hub-cap-for-hub-nut-most-vespa-scooters-182546.html |
Thanks Willo,
That's what I was wondering, if that type of dust caps came on it. I guess I wasn't clear enough with my description of what I needed. Thx for all the info. |
